AAA Recording Stopped after upgrade
Hello, I recently upgraded from 12.1.3a to 12.2.12 on my AS5300. Now the radius (Navisradius) seems to not log the stop accounting anymore. Was something changed that would cause this behaviour? I can see the stop packets but not the actuall accounting for the calls...I know it is an application specific problem, but I thought someone may have seen this issue before.
Re: AAA Recording Stopped after upgrade
You need to run "debug aaa accounting" on as5300 to see the accounting activities between radius server and a AS5300. For more detalied records use
debug aaa accounting and debug radius togather. The format is changed in which the records are displayed in the debug on as5300 from 12.1 to 12.2.
As the debugging output has changed it is hard for me to see what is different between the 12.1 and 12.2 packets that is causing the packets to be rejected on 12.2.
Is there a release note on a change in the accounting packets?
137
