06-29-2012 11:15 AM - edited 03-10-2019 07:15 PM
I have an 1113 acs server which is not booting and hangged. Earliyer its was working but i am facing the problem from today. I capture after reload the devices its asking for press F2 and F12 but when i try to do same its not allow to do the same.(Also attached the capture)
When i try to check the same through connet the dekstop and reload the devices its showing the Cisco logo screen after that its showing the blank screen.
Please let me know is the ACS gone faulty or I will have to try with reimage the devices.
Sunil
Solved! Go to Solution.
07-04-2012 06:32 AM
Hello Sunil,
Looks like a HDD issue. Try with a re-image and if does not work please open a Cisco TAC SR and request a RMA.
Please include this post on the ticket so we can know what has been done.
07-04-2012 06:32 AM
Hello Sunil,
07-04-2012 08:38 AM
Thanks for your reply...
We tried with reimage but still facing same issue. so we checked the HDD with desktop and its working with xp image. So we are going for an RMA.
