ACS 1113 Appliance Recovery CD
I have a ACS 1113 appliance and I need to reset the admin password using the recovery disk however, I have followed the recovery guide to the letter without success.  The problem is the documentation says:
Connect a console to the serial console port on the back panel:
a. Attach a DB-9 to RJ-45 adapter (provided) to the serial port of the console.
b. Attach a DB-9 to RJ-45 adapter (provided) to the serial port of the ACS SE. For the location of the
serial port, see Figure 1-3 on page 1-6.
c. Use an RJ-45 cable (provided) to connect the console to the ACS SE.
It doesn't say what type of RJ-45 cable is provided, straight through, rollover?
It doesn't say what type of DB-9 to RJ-45 adapter to use, Terminal or Null or which one goes where.
I have tried every combination I can think of using straight, rollover with two RJ-45 connectors, and the standard Cisco DB-9 to RJ-45 cable with no success.  I have configured hyper terminal with the correct settings as well but I can never see anything on my console connection.  Any ideas on what  the real connection has to be?
1 REPLY
Re: ACS 1113 Appliance Recovery CD
This might help ( attached is the screen shot of cable and connector you need)
Recovering ADMIN credentials
http://www.ciscosystems.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.2.1/Installation_Guide/solution_engine/admap.html#wp1038722
Jatin
Do rate helpful posts-
~BR Jatin Katyal **Do rate helpful posts**
1166
