Silver
ACS 1113 recovery issue
First time when I boot the ACS 1113 and access through serial port , whenever i put login promp Administrator
not getting any password promt for last 40 mnt only cusor blinking.
Try to recover through CD that also not performing for last two hrs.
Kindly provide solution.
Re: ACS 1113 recovery issue
Its either device is bad or you are trying to recovery with a bad media.
Try to get new media for ACS SE 1113 (Recovery CD)
If still issue exists, go for an RMA.
I am considering that this is a new box that you are trying to configure.
Prem
Community Member
be sure you have your serial console settings set right for the ACS, IIRC they are different than the standard cisco stuff.
179
