Community Member
ACS 1121 Gigabit 0 not working
I have an ACS 1121 appliance newly shipped and the gigabit 0 interface worked initially but after reload it didn't anymore.
Any hints?
Re: ACS 1121 Gigabit 0 not working
Hi k abillama,
Make sure you have connected to port 6 because port 2 and 5 are the (Blocked) Gigabit Ethernet.
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/installation/guide/csacs_hw_ins.pdf
As you said that it worked initially but stop working after reload, it could be a hardware issue as well if the conneciton has been made as per document mentioned.
thanks,
Vinay
Thanks & Regards
Community Member
Hi vinashar,
I double checked and it's correct! During the initial setup it was working but then and after reloading the appliance it didn't work anymore. The other interface is working normally. Could it be a bug?
335
