03-12-2003 04:23 PM - edited 03-10-2019 07:12 AM
Can I use ACS2.6 for PIX 6.2.2 command authorization. I used "Cisco - Authentication and Command Authorization for PIX 6.2" as my reference. The doc talks about needing a patch for ACS3.0. Is there a need for a similar patch in ACS2.6
03-13-2003 11:29 AM
You can see that if you have ACS 3.0 then only you need a patch due to bug CSCdw78255 which is found in 3.0(1). Since CSCdw78255 is not reported against 2.6, you don't need any patch for that
03-18-2003 01:57 PM
i turned the page in the documenation and saw that forgot to add aaa authorization command TACSERVER command. Once entered, it worked fine.
