ACS 3.3 Solution engine Certificate
aalsayed
i have acs 3.3 SE and i am trying to run PEAP for wireless client so i created certificate using CSR but the validate periode for certificate is one year ,,
1- haw i can exptend this periode .. like 5 years
2- if i run self signe certificate (default is one year ) . that is mean i ahve to instal the new certificate every one year to the client whihc is hedck ,, if i unchekc the validate server certifiacte ... will effect the security and what will be the behavior for bothe client and acs if i want to connect after passinf one year
3- did there another one to install certificate to the acs SE like normale acs software using microsoft CA
Vivek Santuka
The slef signed certificate is valid only for 1 year. This cannot be extended.
After the certificate expires, the users will not be able to login.
You can install a certificate issued by a Microsoft CA or a third party Certificate Vendor.
Do you need the procedure for installing the certificate ?
