02-15-2006 06:30 AM - edited 03-10-2019 02:28 PM
We are phasing out External DB authentication for Novell. We would like to identify and delete all ACS users that have "Novell" as their Password Authentication type.
Is this possible?
I have been playing with csutil.exe and there appears to be nothing that will let me enumerate "user" AND "Password Authentication" as criteria for export.
02-15-2006 06:42 AM
No easy way to do this, but I could write something that would work.
If interested please use the contact page on extraxi.com
Darran
02-15-2006 07:52 AM
Ok, what's the catch?
We are planning an upgrade to ACS 4.0 next fiscal year and you said it yourself, ACS 4.0 has a purge mechanism built into it for Ext_DB users.
I know we can dump the database to clear text and there is a lot of user information specified at that point. I just need to know what field in that dump is specifying the "Password Authentication" type and what's the encoding on that field.
This will be a one time process and we really don't want to spend any money on ACS 3.3(3.11)
02-16-2006 12:39 AM
..in which case the cheapest option is to postpone this until after you've upgraded to 4.0
Darran
02-16-2006 06:59 AM
ah man, your killing me here...oh well, I totally understand. You have to make your maoney too.
Thanks for all your help.
