ACS 3.3 vs ACS 5.1
I am trying to figure out how to tie a command authorization set to a shell profile in ACS 5.1.
In ACS 3.3 within the Shell Profile there is a section that has a drop down menu where you select the command auth set
you want to associate with the Shell. In 5.1 when I go to the Shell Profile there is no such menu just
three tabs (General, Common Tasks, Custom Attributes) and nowhere do I see how you add in a command auth set for the Shell.
Can someone direct me to the documentation for this, or how you actually accomplish this?
Jim
Re: ACS 3.3 vs ACS 5.1
Jim
Hi Jim,
Check out the below link hope to help !!
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/migration/guide/Appendix_A_ACS_missing_Attributes.pdf
Ganesh.H
Hi Ganesh,
Thank you for the link it explained why I do not see where the command authorization is located in the shell as in ACS 5.1
it is done on a per user basis. However, when a user is configured I see no where to attach a command authorization set.
The only thing you can define for a user is the Identity Group which is a purely logical container as the documentation you provided
points out. Would you know where the per user command authorization is applied?
Jim
I finally found where the configuration of the command sets takes place it is in:
Access Policies > Access Services >  Default Device Admin >  Authorization
Thank you all for your help.
430
