11-14-2005 10:18 PM - edited 03-10-2019 02:22 PM
I have configured the acs 3 to authenticate vpn clients which connect onto the pix 6(3)5 and then the acs sends dynamic access lists to the pix according to the user. the problem is that after say 4-5 days no one can connect using the vpn client and the only thing to do is to restart the pix. this goes on for 4-5 days again and then I must restart again the pix.
any advice?
11-18-2005 01:08 PM
The issue may not be related to the ACS, but could be within the PIX itself. If you have a spare PIX, swap it and see what happens.
11-20-2005 10:17 PM
The pix came with 6.3(3) and it was doing the problem almost everyday. with the 6.3(5) it does the problem every 4-5 days. its kinda wierd. is there a command which i can use to somehow clear the vpn connections automaticaly. because when the problem arises. the pix works fine for other things like internet. only the vpn client does not work.
