acs 4.0 tacacs+ key
I am trying to use a ACS appliance for switch TACACS+ authen. I'm getting a key mismatch, however I don't actually remember setting a key for TACACS on the ACS appliance. How do I reset / find out where this is set??
Thanks.
1 ACCEPTED SOLUTION
Re: acs 4.0 tacacs+ key
1. ACS side:
- Login to the ACS via web browser
- On ACS main menu, check the switch configuration status (called AAA Client) under "Network Configuration - AAA Client".
http://www.cisco.com/en/US/products/sw/secursw/ps5338/products_user_guide_chapter09186a0080233613.html#wp142681
- Check the switch details, and check the stated secret key. You may re-enter the same key or define new key (without extra space or characters).
- Compare or use this key in the switch, which is configured under "tacacs-server" parameter.
- Save the config
2. Switch
- Login to the switch CLI (console/telnet/ssh)
- Scroll down to the 'tacacs-server key' configuration line.
http://www.cisco.com/en/US/products/hw/switches/ps637/products_configuration_guide_chapter09186a008007f032.html#xtocid238207
- Delete the exisitng key (normally hash/encrypted). Enter the same key - without extra space or characters.
- Make sue you're pointing to the correct ACS Server/IP
- Do not save the config yet.Test the tacacs+/AAA authentication to verify that both ACS server and the switch used correct/identical key.
Hope this helps. Pls rate all useful post(s)
AK
1 REPLY
1. ACS side:
- Save the config
2. Switch
AK
156
