ACS 4.1(1) Build 23 Patch 5 with MDA authenticates phone in DATA domain
I configured MDA on a 3560 (c3560-ipbasek9-mz.122-53.SE2.bin) with ACS 4.1(1) Build 23 Patch 5 as documented in attached pdf file.
Unfortunately the Cisco IP Phone 7941 authenticates in the DATA domain and not in the VOICE domain.
Does anyone know what's wrong?
Regards, Peter
1 ACCEPTED SOLUTION
Re: ACS 4.1(1) Build 23 Patch 5 with MDA authenticates phone in
     What browser are you using to define the AV Pair on ACS?  Please reinput the AV Pair on ACS using Internet Explorer and see if this makes a difference.
--Jesse
Some additional info:
Seems my ACS server sends a malformed AVpair back to the switch which it doesn't understand.
RADIUS:   Cisco AVpair       [1]   40  "device−traffic−class=voice"
This should look like this I think:
RADIUS:   Cisco AVpair       [1]   28  "device-traffic-class=voice"
Is this a bug in ACS 4.1(1) or maybe in the switch? What can I do?
Best regards,
Peter
--Jesse
Thanks a lot. As a matter of fact it worked already since I manualy put in the AV pair letter for letter.
So this was a copy paste problem.
Case closed!
310
