acs 4.1
Hi Community,
I would like to know if it is possible to run acs 4.1 to authenticate alcatel pabx users.
I authenticate the users on the 2950 cisco switch with acs 4.1 however i don't see in reports of acs 4.1, successful authentication?
can you help me please ?
thanks in advance
Joseph
Network Engineer
Re: acs 4.1
to see successful login on a new installation you need to turn on Passed Authentication Reports from,
System Configuration > Logging >.... CSV Passed Authenticaiton.... > Check it to turn on.
IF alcatel pabx supports Radius and/or Tacacs, ACS will authenticate the users on that box.
Prem
Please rate if it helps!
Re: acs 4.1
Thanks for your reply, he helped me to resolve this issue.
I have another issue : In the reports, i don't see incrementation of AAA Client in Logged-In Users, must i configure one thing in acs to view users logged inside the system ?
Thank you for your response.
Joseph
Re: acs 4.1
Your network devices must be configured to send accounting information to the ACS server.
i.e.
You router/switch should be configured with commands like,
aaa accounting exec default start-stop group ....
Prem
Re: acs 4.1
I want to know if it is possible to authenticate MICROSOFT WINDOWS SERVER through ACS.
can you tell me the headlines to perform this task please ?
Thanks for your help
Joseph
Re: acs 4.1
your question is not clear enough. If you want to ask, that can ACS authenticate users whose credentials reside on Microsoft Active Directory, then the answer to that question would be yes.
Please refer ACS documentation,
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/user/guide/UsrDb.html
Prem
Please rate if this helps!
239
