acs 4.2.1.15 and ssh authentication with ios xr
t.waibel
we have a new acs appliance (1113) with version 4.2.1.15 and we want to authenticate user through ssh from routers with ios xr software. unfortunately this doesn't work.
Here ist our configuration of the router:
line template VTY
access-class ingress abcd
tacacs-server host x.x.x.x port 49 single-connection
tacacc-server key 7 test
tacacs source-interface Loopback13
ssh server v2
ssh timeout 60
! AAA config
aaa accounting exec default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting commands default start-stop group tacacs+
aaa authorization exec default group tacacs+ none
aaa authorization commands default group tacacs+ none
aaa authentication login default group tacacs+ local
does anybody has a solution for this problem?
thnx and best regards
Torsten Waibel
5 Replies 5
Ganesh Hariharan
line template VTY
ssh server v2
ssh timeout 60
! AAA config
Torsten Waibel
Hi Torsten Waibel,
For ssh to support you should have a cryptography ios image in router and check the following command in line vty that transpot input ssh under line vty cofiguration.
If helpful do rate the post
Ganesh.H
Hi Ganeshh,
sorry, i forgot to tell that we have an old acs appliance 1112 working with 4.0 with ssh authentication working properly.
This includes that we do have cryptography ios images.
So in my opinion the problem is maybe located at the new acs software 4.2.1.15.
Best regards
Torsten
Hi Ganeshh,
Best regards
Torsten
Hi Torsten,
I dont think it can be problem with acs version can you check that your are able to do telnet and logs are coming into acs.
Ganesh.H
t.waibel
problem is solved!
Best regards
Torsten
problem is solved!
Best regards
Torsten
Hi Torsten,
It will be helpful if you can share what was the problem so that other get beniffted with your post
Ganesh.H
