05-25-2009 12:55 AM - edited 03-10-2019 04:30 PM
Hi there
is it possible to use an ACS and a CA Server with 4096 bit certificates?
Until now we tested with selfsigned 1024 bit certificates. Now I am not sure, I we can install a 4096 bit certificate on the ACS and if it can handle 4096 bit client certificates?
Thanks in advance.
Dominic
Solved! Go to Solution.
05-25-2009 06:35 AM
Dominic,
You can use 4096 bit certificate from ACS 4.2.0.124 patch 10 onwards.
~JG
Do rate helpful posts
05-25-2009 06:35 AM
Dominic,
~JG
05-25-2009 10:19 AM
Hi JG
thanks a lot.
Dominic
