Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
ACS 4.2 profiles with Tacacs ?
Hello
I use ACS 4.2 (applicance) with Network Access Profiles. It's a very big problem that profiles support only radius protocol, i need to use tacacs protocol with profiles.I need tacacs for command authorization. Is there any way to have such a rules on ACS 4.2:
- if logging from NetworkDeviceGroup1 using radius use local authentication
- if logging from NetworkDeviceGroup2 using tacacs use RSA securID (external Radius authentication).
Best regards,
1 ACCEPTED SOLUTION
Silver
on ACS 4.X NAP only works with radius.
- if you want you can go to ACS 5.X , which is more flexible.
it run role based authentication / authorization and you can combine roles you need in more flexible way.
please check these links:
1)     http://www.youtube.com/watch?v=Xin98O-Q4JY
2)     http://www.youtube.com/watch?v=vOxcrEU_-Gw&feature=related
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/user/guide/access_policies.html
Kind regards
Talal
Don't forget to rate answers that you find useful
please rate answers that you find useful , and mark as answered - when it is :-) - so others can find it easily
1 REPLY
Silver
Kind regards
Talal
313
