Community Member
ACS 4.2 trial ver installation problem
I have been searching the net for quite some time, for what it could be the reason why the admin page on http://127.0.0.1:2002 do not open, after successfully installed the ACS 4.2 on Win-2003 SP1.
I did installed Java 6.0 and the two JRE patches and I used Firefox as the browser, but all invain.
Any idea what else I need to do more.
Thank you
Sam
1 ACCEPTED SOLUTION
Community Member
Re: ACS 4.2 trial ver installation problem
Hi Sam,
Do you have another applications install on this server?
I will suggest to install the ACS on a fresh installation of windows 2003.
Sam,
Please check if all services are running, like csadmin, csradisu, cslog etc.
~JG
Community Member
Hi Sam,
169
