08-04-2009 11:17 AM - edited 03-10-2019 04:37 PM
Folks,
I just installed ACS 4.2 on windows 2003 server, when i connect to the acs remotely, it asks me for a username and password. I remember setting up a password for admin when installing,but i do not know the username??? please help.
08-04-2009 12:04 PM
ACS administrator user accounts are stored separately from the regular user database. You probably don't even have any ACS administrator accounts created. RDP to your Windows server and run ACS web admin on there. You will not be prompted for user/password to login. Then go to the Administration Control and add admin user accounts. Then you can use ACS web admin remotely.
Roman
08-04-2009 07:42 PM
Thanks I tried to do that at the server where acs is installed, but when the administration page comes up, when i try to fill up the form for the admin user, it does not access and gives me a error on the page, it seems i require a certain version of java on that machine as well? the page itself gives me a error and does not let me submit the new admin account i created.
08-04-2009 07:44 PM
08-05-2009 12:45 AM
1)turn off pop
2)add in trusted website in windows 2003 server
3) install Java 6(TM) update 14
thanks
Karthik
