ACS 5.0 with PEAP
Hi there
i saw the following table about authentication protocols in ACS 5.0:
PEAP (with EAP-MSCHAPv2 inner method) Yes
PEAP (with EAP-GTC inner method) No
PEAP (with EAP-TLS inner method) No
EAP-FAST (with EAP-MSCHAPv2 inner method) Yes
EAP-FAST (with EAP-GTC inner method) No
EAP-FAST (with EAP-TLS inner method) No
In my opinion this should work for every Microsoft windows clients, right? Are there any clients today which still use EAP-GTC or EAP-TLS?
Thanks in advance and best regards.
Dominic
1 ACCEPTED SOLUTION
Re: ACS 5.0 with PEAP
Hi Dominic,
EAP-GTC is Cisco propritary, so its meant to work with Cisco products only. But, I also saw that we've an option for EAP-GTC on IBM utility.
In order to enable EAp_GTC, you can use either one of them:
Cisco350card
Cisco ACU utility
AS far as EAP-TLS is concerned, It will work with all Microsoft clients as EAP-TLS protocol is an IETF open standard.
EAP-TLS is supported by the following operating systems (natively):
* Mac OS X 10.3 (and above),
* Windows 2000 SP4
* Windows XP
* Windows Vista
* Windows Server 2003
* Windows Mobile 2003 (and above)
* Windows CE 4.2
JK
~BR Jatin Katyal **Do rate helpful posts**
Hi Dominic,
Cisco350card
Cisco ACU utility
* Windows 2000 SP4
* Windows XP
* Windows Vista
* Windows CE 4.2
JK
Hi JK
thanks a lot, that was what I needed to know.
Dominic
242
