ACS 5.0
Leo Bruni
I have just installed the ACS 1120 appliance with ACS 5.0. It was working fine for about a week. Now however I am getting the following error message when I try to start monitoring: The monitoring and reports database is currently unavailable. Attempting to reconnect in 5 seconds.
ThibaultMean
Hi there,
i thin kthe answer is in a previous post.
using the CLI, enter the following command:
show applicaion status acs
That should tell you wether all the services are running.
Anyway I fixed by reloading the box (which is not great).
Regards.
I have checked the application status and it states that all processes are running. This includes the database process. I also have now reloaded the box at least 10 times with no change.
If all services are running, then it could be an issue that would need greater debugging from CLI.  If this is a new install that hasnt been moved into production yet, I would suggest re-imaging to the latest version of ACS (5.1 Patch level 3)
-Mike
phamthanhchuong
Can anyone send to me ACS 5.0  configuration document?? i don't know how to config acs 1120 appliance
Please, i need argent
Thanks for support
