ACS 5.1 authentication issue from cross domain user
Hi All,
         we have cross domain trust relationship established and I have added the user group in our ACS 5.1. we are using Active directory as an external Identity store. Also I have created a rule in the 'Access polices' to allow the user group. From the cross domain, I use abc@xxx.xyz as a user id, but I get this error message
13036 Selected Shell Profile is DenyAccess
Your quick help will be appreciated.
Rgds
HK
It would be worth seeing at which point this is failing
Go to Monitoring & Reports > Reports > Catalog > AAA Protocol and select "TACACS_Authentication" and then select the "Details" icon. This should give the detailed steps performed during the processing of the flow
Hi Jrabinow,
                   Thanks for your reply and information. I have sorted out the issue, which was in path defined in (Access polices) rules section. After correction, the cross domain user has got access and permitted.
Thx
Hid
My friend's problem was access policy in Shell profiles, more hugs by the way has already solved.
3839
