ACS 5.2 to ACS 5.3 Application Bundle
I have a seen a few post about this but no fix yet. Wondering if anyone has had success?
I just upgraded to latest patch 5.2.0.26-10 and then tried the application upgrade command to install 5.3.0.40 and I get the Manifest file not found in the bundle error.
I have tried stopping ACS and installing and still doesn't work.
Brad
Everyone's tags (6)
Which repository are you using? Tftp gives this error usually and your best bet is to use ftp.
Tarik Admani *Please rate helpful posts*
I am using FTP. I just tried to extract file and it is throwing an error. I am going to re-download the package.
If you dont mind pasting the entire command that will help also.
Tarik Admani
  I'm having the same problem when trying to patch for ACS   up to 5-3-0-40-2.tar.gpg
i'm using FTP server.
I can list the files in my repository, with sh repository.
any solution to this  ?  i'm no trying to downlaod again and try.
Did not help with the new download....
I did this a week ago, then it worked perfectly.
okei ... pretty embarresing ... i forgot acs install, i just went with install ....
works now... don't mind me
1016
