Community Member
ACS 5.3 Occurred At: Tue Sep 10 04:00:00 IST 2013 Cause: Purge Configuration Repository not configured
hi team,
I am runing ACS 5.3 version and i am getting error messages like below
System Alarm [Database Purging]
Incremental Backup Not Configured
: Configure Remote Repository under Purge Configuration which is used to take a backup of data before purge.
: Incremental Backup Not Configured
: Incremental backup is not configured. Configuring incremental  backup is necessary to make the database purge successful. This will  help to avoid disk space issues. View database Size is 1.27GB and size  it occupies on the harddisk is 1.22GB.
Could any one provide solution to overcome this issue.
I guess I've seen this before even we've repository and incremental backup configured fine on ACS. One reason could be for the above alarms is the configuration on the GUI might not have taken over completely in the database and alarms will trigger due to that. Please restart the services of the ACS or reload the ACS in off production hours.
acs stop
acs start
OR
reload
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin Katyal
Community Member
Hi Jatin Katyal
I restarted ACS but still i am getting same error message.
When i checked show backup history in ACS through cli, backup is success. But i am getting above error message.
Could you please help me on this
Rajkumar
What is the complete version of ACS (along with patch) are you running in your enviornment?
~BR
Jatin Katyal
~Jatin Katyal
Community Member
Hi Jatin Katyal,
Please find the ACS Version 5.3.0.40.9
Rajkumar
Community Member
Hi There !
I am also facing the same issue .Could you please help me out.
601
