10-09-2014 12:07 AM - edited 03-10-2019 10:05 PM
yesterday I installed patch 7 for ACS 5.4.
During Installation a warning was shown about exceeded disk quota (which might be usual, as some notes on cisco.com show).
The installation continued, but after reboot the command: "show application version acs" showed still the old version "5.4.0.46.5 Internal Build ID: B221"
I tried to patch once again, but now: "the patch is already installed"
is there something wrong with my machine or with the patch?
Thank you
Karl
10-21-2014 08:10 AM
Karl,
Were you ever able to get the already installed patch installed or validated is the term I read? I'm having the same problem with patch 5-4-0-46-7.
Thanks for any assistance.
Adrian
10-21-2014 10:55 PM
Hi Adrian,
no, I didn't try it again, I wanted to wait, if someone could tell me about the issue.
But I think it's not urgent, because I disabled sshd, the workaround for the SecAdvisory.
I'm still waiting for an answer from Cisco.
Karl
02-24-2015 03:17 AM
I think, though the device shows the wrong version, the patch is installed.
last week I've upgraded to 5.6 without problems (upgrade-path should have matched)
01-29-2015 04:07 PM
Hi!,
Any update about this??? i have the same problem with the 5-4-0-46-7 patch
