ACS 5.4, Nexus 7k - User Roles not correct
Hey all,
It would appear that from the amount of times this has been brought up, its still an issue!
I have a Nexus 7k that needs TACACS auth to a Cisco ACS 5.4, but everytime i do it sticks all of us users into a default role of vdc-operator
I have created a shell profile with the following:
Attribute: cisco-av-pair
Requirement: Mandatory
Attribute Value: shell:roles*"network-admin vdc-admin"
But still our users are put into vdc-operator, ive found many different suggestions of how it should look but not a single one works?
Silver
Hi Daniel,
Could you try to use this:
Have you verified if the roles are assigned back in the authorization logs?
**Share your knowledge. It’s a way to achieve immortality.
--Dalai Lama**
Please Rate if helpful.
Ed
**Share your knowledge. It’s a way to achieve immortality. --Dalai Lama** Please Rate if helpful. Regards Ed
Thank you for your help Ed
Sadly its still the same, im going to look at the logs now
I also had this issue and I
I also had this issue and I think I just found the the fix through trial and error... We are running ACS 5.4 and just put in a set of Nexus 7710's running NX-OS ver 6.2.6. In our ACS shell profile I had to change the value to: shell:roles*"network-admin,vdc-admin" and from what I can tell this is allowing me full access to my default and non-default VDCs. Hopefully this will work for others.
Thanks, this help fixed my
Thanks, this help fixed my issue.
579
