ACS 5.8.0.32 not matching Active Directory Authorization Rules for TACACS after upgrade from 5.6
fuhrersk8
Level 3
Level 3
Hi Guys;
    We had a primary/secondary ACS 5.6 deployment working beautifully with all of our switches authenticating (TACACS) with our Active Directory accounts.
We decided to upgrade to version 5.8.0.32. Both virtual machines upgraded successfully (at least that was the message form each vm after upgarded).
 But, after the upgrade, bot ACS were disconnected form the AD. We rejoined both of them successfully, but now, after the upgrade, all of the authorization rules referencing AD (active directory accounts) are being ignored and it goes directly to the default deny rule.
The local accounts existing on the ACS authenticate successfully. It is the Rules referencing AD accounts.
All diagnostic tests pass successfully., ecen in the ACS logs, the users from AD gets authenticated, but in the authorization rules  the ACS ignores the existing AD rules and uses the Default deny Rule.
Any ideas?
Thanks in advanced Guys!
22 Replies 22
radmedur
Can you please confirm whether Binary certificate comparison is enabled in Certificate Authentication Profile object?
I mean the whether following check box is enabled?
"Perform Binary Certificate Comparison with Certificate retrieved from LDAP or Active Directory"
This configuration is available in GUI "Users and Identity Stores > Certificate Authentication Profile"
If yes, can you please disable and try.
If not, Can you please share the list of steps shown in the report in failed case.
Radhakrishna
Hi and thanks for your reply;
   It was disabled. I proceeded to enabled it, but same result. The rules related to AD1 authentication are ignored and authorization is denied by ACS.
Below the steps of a failed authentication attempt of my AD Account on a Cisco switch:
StepData=19=c191341 : StepData=20=na.am.lilly.com : StepData=21=corp.lilly.com : StepData=23=C191341@na.am.lilly.com : StepData=26=C191341@na.am.lilly.com : IdentityAccessRestricted=false
Thanks again.
Did you access ACS 5.8 via Chrome as a browser? The Reason I am asking because no version of ACS supports Chrome browser - ACS browser Support and we have a very severe defect on this where it corrupts all the authz rules and no matter how authorization works for an user, it always take you to default policy that is set to deny in majority of the cases. In order to fix the issue do this:
Use supported browser and check whether all policies and its rules and conditions are displayed correctly and resubmit all of them. Restart ACS services to get the latest changes into effect.
~ Jatin
~Jatin
Hello and thanks for the information.
I am using Mozilla Firefox 43.0.4.
What does resubmiting the policies refers to?
Thanks again.
so basically it messed up all the operators that we use to create conditions with external AD groups. I would like you to review all the authz rules and ensure the and/or operators are still intact. Once done - save changes again. Restart the ACS services from the ACS CLI and test again.
~ Jatin
~Jatin
Hi;
   Basically, I deleted and recreated the AD rules, but still no authorization is being allowed but the default deny rule.
Even the Authorization rule for administering the ACS is being bypassed into the default rule.
Thanks again.
We need more details on the issue. For example as i mentioned "Steps" in the Authentication/Authorization reports. The step details you have shared are not useful here.
For specific authorization failure, please click on "Details" icon which will open new window. In the new page, please go to end and there are steps mentioned. please take the screenshot and attach here.
Radhakrishna
Hi;
  Attached more information.
Thanks for your support.
Hi fuhresk8,
Could you please configure "AD1:memberOf"  instead of "AD1:ExternalGroups"  to check whether the authorization is working fine.
We suspect that this is the permission issue to fetch the "TokenGroups" attribute.
Please let us know the results after configuring "AD1:memberOf" attribute.
Priya.
Hi Priya and thanks for your support;
    Did as you mentioned, but same result.
Thanks again.
I've the same problem. On 5.7 there was no problem, see screendump. You see the external groups
On the 5.8, same config & access policies, there is no AD group matching.
As you see, there are (the same) directory groups, with Group SID. I've checked the SIDs and are correct.
Anybody a hint?
Can any one of you please raise SR, so that DE team can analyze logs and confirm the issue.
OR
please attach the support bundle here.
Radhakrishna
SR638838907
Thanks we will work on this.
