ACS 5.x RADIUS VSA Configuration
jennyjohn
I need to configure RADIUS VSA configuration for a my alvarion device. Following are the attributes that need to be configured.
- Packet Data Flow ID (ID 1, integer16)
- Direction (ID 4, integer8)
- Transport Type (ID 6, integer8)
- UplinkQoSID (ID 7, integer8)
- DownlinkQoSID (ID 8, integer8)
- Classifier (may be multiple instances) (ID 11, String)
    * ClassifierID (ID 1, integer8)
    * Priority (ID 2, integer8)
    * VLAN-ID (ID 9, integer16)
    * Classifier Direction (ID 4, integer8)
I was able to configure the first 6 attributes, how can I add the Sub - TLV's ClassifiedID, Priority, VLAN-ID and Classifier Direction which come under Classifier. Don't see any option for that in ACS 5.x
Thanks in advance.
jennyjohn
The method is to define an attribute with an octet or binary type and calculate the binary values…
example:
VLAN-CS: Classifier Id=1 (010301), priority=0 (020300), direction = bi-directional (040303), CVID=61 (0904003D) --> 0103010203000403030904003D
Cisco ACS 5.x has an option to select the Attribute Type as Hex String, but unfortunately I could not find any option to add the value to the attribute (Policy Element> Network Access > Authorization Profiles and on the RADIUS Attributes tab). All Attributes with type Hex String and not shown at all.
How can I define a octet or binary type VSA attribute in Cisco ACS 5.x?
