ACS and AD Group Integration for 802.1x
mironduplessis
Does anyone know if it is possible for the Radius Server to use the groups of AD to determine which vlan to put a user in when using 802.1x control on switch ports.
Miron
Jagdeep Gambhir
Level 10
Level 10
Miron,
I'm not sure which radius server we are using? I have this 3rd party link that explains about setting up AD/IAS for dynamic vlan assignment.
http://www.brocade.com/downloads/documents/white_papers/wp-install-guide-dynamic-vlan.pdf
This should help
~JG
Do rate helpful posts
