09-25-2003 08:36 AM - edited 03-10-2019 07:30 AM
Does anybody know how to set the logout to 60 minutes on CatOS based switches when performing AAA through Cisco Secure ACS Server. I do not want to use the auto command attribute and Idle-timeout only seems to apply to IOS?? I think it can be done with custom sevice/attributes which can be turned on under the Interface Configuration-Tacacs+. Thanks for your help in advance.
10-01-2003 07:24 AM
If I understand you correctly, you want to set the time until an idle session is disconnected automatically. You can set the logout time on the Cat 4k/5k/6k using the set logout command. For the Catalyst 6000 series, the default is 20 minutes and you can set it from 0 to 10,000 minutes. More information is available at http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_7_2/cmd_ref/set_m_pi.htm#xtocid0.
10-01-2003 08:26 AM
I am looking to pass that setting from Cisco Secure ACS when logging into a Cat 6000 running CATOS. I don't want to use the autocommand. But still, thanks for your suggestion.
