ACS Appliance 1113 CAN'T FIX Ip Address.
Hello Everybody, I have a CISCO ACS 1113 with release 4.1.1 build 23 patch 5. I can set the IP ADDRESS using the CLI but the problem is:
1) After some time or after a reboot the appliance the IP ADDRESS is lost. In this moment the network adapter is using the default ip address 169.254.x.x or requesting a new IP by DHCP. I need a sugestion to FIX the IP on netowrk adapter in this case ?
Bronze
Re: ACS Appliance 1113 CAN'T FIX Ip Address.
It seems like you are matching:
CSCsm73656 - Cannot set static IP
[Symptom]
Cannot set static IP on CSACSE-1113-K9.
Try applying this patch:
applACS-4.1-set-ip-CSCsm73656-Patch.zip
ACS SE patch for "set ip" CSCsm73656
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
there is a bug filed for this behavior, you would need to download a patch and apply this patch to the ACS appliance.
259
