ACS appliance multiple interface usage
dehghan
Is it possible for me to use the two interfaces that are available on the 1113 box? I want to connect both of these interfaces to two seperate network segments. I did not find any thing specific in the Cosole except the set ip that would only config one interface.
thanks
You can use only one.
Your Cisco 1113 system has two integrated 10/100/1000-megabit-per-second (Mbps) Ethernet connectors. ACS SE supports the operation of either Ethernet connector, but not both connectors.
For more check here
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.1/installation/guide/solution_engine/ovrvuap.html#wp1054065
For more check here
sarmohan
The Cisco Secure ACS Appliance supports the operation of only one Ethernet connector at a time. Concurrent operation of both Ethernet connectors is not supported.
Saravanan
Is there any plan for the support of the second interface in later releases? This second interface might become very usefull sometimes.
thanks
No. as of now there is no plan to make BOTH NIC operational at a same time.
~JG
