ACS: certificate field (OU) validation
Hello
I have non-cisco WLAN solution, every client has it's certificate and login to SSID=AllNetworks using that certificate. ACS4.2 is used. It works fine.
I want to make 3 SSIDs for each of the departments.  Each department uses different NAD (network access device), so i created 3 seperate profiles for that.
I want to authorize certificates only when they have specific OU=Department1(2 or 3) for specified profile.
I can not find any options handling mapping of certificates fields in ACS4.2. Is it possible in ACS4.2 ?
Is it possible in ACS5 ?
Thanx
  • AAA Identity and NAC
343
