04-21-2008 10:35 AM - edited 03-10-2019 03:48 PM
I have ACS solution engine, I made a NDG on ACS and add AAA server and AAA client. I also made a user in default group 1. The same user exist
in rotuer local database just on the safe side. But I am not able to see any activitiy in ACS reporting window,
not able to see any logged user in ACS.
The following is the configuration that I did on ACS engine and router
aaa authentication login default group tacacs+ local
aaa authorization exec authorization group tacacs+ local
aaa accounting commands 15 accounting start-stop group tacacs+
username cisco password cisco123
tacacs-server host 172.28.31.132
tacacs-server key <tacacs-shared-key>
ip tacacs source-interface gig 0/1
04-21-2008 01:32 PM
You mean you can authenticate fine but do not see any command accounting ? If that is the case,then pls note that Command accounting logs are stroed in tacacs administration logs.
Also there is a known issue on ver 4.1.1 and we need to apply patch ACS 4.1.1.23.5 to fix the command accounting issue.
Patch for appliance is available on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des
Patch name : ACS SE 4.1.1.23.5 accumulative patch
Patch for acs windows is available on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des
Patch Name : ACS 4.1.1.23.5 accumulative patch
That should fix the issue,
~JG
04-21-2008 04:30 PM
but I am not able to see complete logging of all commands that I am using during the session. I configure the following things on router
aaa new-model
aaa authentication login default group radius local
aaa authorization exec authorization group radius
aaa accounting commands 15 accounting start-stop group radius
aaa accounting exec default start-stop group radius
aaa accounting network default start-stop group radius
radius-server host 172.28.31.132
radius-server key waridtel0321
ip radius source-interface gig 0/1
Please tell me how i can see which activities user has performed during the session. detail of command.
Can i use tacacs for authentication and radius for accounting. I tried it but it didnt work for me.
Please guide I will be very greatful to you.
in Tacacs accounting CSV file, it shows me only login time, user id and service shell, i want to see detail of command that user has used during the session.
I have attached both CSV files that i got when trying with tacacs and radius for accounting.
04-22-2008 06:52 AM
Command accounting is only possible via Tacacs and not radius.
So you need to use tacacs and these logs would be logged in tacacs administration logs.
~JG
Do rate helpful posts
