02-02-2010 06:13 AM - edited 03-10-2019 04:55 PM
Dear All,
I'm trying to install an ACS Solution Engine in My network for access control (AAA). I succeed in setting up authentication using the internal database and that works. now My boss want users to be authenticated through an external database (windows AD). I tried achieving this but kept getting different errors.(like EAP-TLS or PEAP authentication failed during SSL handshake) or (Authen session timed out: Challenge not provided by client).
please I need someone who has done this before to give Me a step by step procedure on how I can setup ACS SE for windows authentication.
02-02-2010 06:34 AM
Hello mate,
first you have to configure an external identity store pointing to your active directory
then you need an access policy for your wireless service with
an Identity Policy where you define the identity result as your Active Directory store
an Network access Authorization Policy where you define a rule with a compound condition, where you set the dictionary ( AD-AD1) to match any active directoy users.
regards
Alex
02-02-2010 06:51 AM
Hello Alex,
Please help with a step by step procedure to actualize the points you gave.
thanks
Lucky Julius.
Network Engineer
UNICEM NG
On Tue, Feb 2, 2010 at 3:34 PM, alex.dersch <
02-02-2010 07:09 AM
Hello Julius,
i don't have screen shots or a document for the set up of ACS 5.1 but it similar to LDAP integration. Maybe open a TAC engineer he can walk through the config with you by webex.
cheers
Alex
