ACS control
gaboughanem
Hello ,
i have a remote vpn users connecting to our network and one vpn group can access specific servers ( controlled by access-list )and there are authenticated by ACS.
the problem is that in the same vpn group ,some users should be able to access some servers and not all.
for example if i allowed in access list 10 servers to be allowed to access. i need some user to access only 2 servers.
Can this be done by creating account on ACS and restrict the access in the same vpn group?
Thank you and Regards.
Jagdeep Gambhir
Level 10
Level 10
You can set it up using NAR in ACS.
http://cisco.com/en/US/products/sw/secursw/ps2086/products_tech_note09186a0080858d3c.shtml
~JG
Do rate helpful posts
Thank you JG for your fast response, i tried NAR to restrict access to network devices that are athenticated by ACS. but is it possible to restrict access to servers (windows /sun...) which are not athenticated by ACS.
