ACS EAP-FAST and LEAP restrictions. regarding 7920 wireless phones
Hello, The 7920 still doesn´t support EAP-FAST. So I´m wondering if it is possible to restcrict EAP-FAST users from turning LEAP on. Is there a way in ACS to do that ?
Re: ACS EAP-FAST and LEAP restrictions. regarding 7920 wireless
You can disable LEAP support on a global basis via
System COnfiguration -> Global Authentication Setup
And disable LEAP, by unchecking the LEAP checkbox
Thanks but I am running LEAP for the phones so I don´t whant to do that. I was wondering if this could be restricted so only 7920 phones could use LEAP but others only EAP-FAST. I cant see a way but I wanted to doublecheck if there was a solution.
Super Bronze
Kristjan's question above is a good one - I'm looking for a similar answer...
I.e. can I add all my 7920 handset usernames to a group, and only allow these to do LEAP?
Also can I restrict LEAP users to a set of pre-defined MAC addresses?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
I am facing the same problem, does anyone get an answer or an idea ?
thanks
Luc
Silver
If you can upgrade to ACS v4.0, then you can use the Network Access Profile feature by which each specific network service can have its own authentication and authorisation policy.
If you IP phones all go into an NDG you can create a specific policy just for than NDG.
et voila!
226
