ACS Read Only Device Access
dtom
We are using ACS ver 4.2 and trying to setup users with limited access to our switchs and routers.  Here is what we did:
1) Created a user in ACS
2) Create Shell command Autorization Set - ReadOnly
          Unmatched Commands - Deny
          Commands Added
               show
               exit
          * this should limit the user to the show and exit command only (correct)?
3) Created a group - HelpDesk with the following TACACS+ Settings
          Shell (exec) is checked
          Priviledge level is check with 15 as the assigned level
          Assign a Shell Command Authorization Set for any network device - selected
          ReadOnly - shell command autorization set seleted
When the user logs on to the router/switch it appears that he has full access.  He can enter the enable command, config terminal command, etc.  All we want him to be able to do is to issue the show command.
2 Accepted Solutions
aneelaka
Can you refer to this doc
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml
and compare the config, as far you say ACS config sounds correct on the switch/router you need to have the following command also
aaa authorization config-commands
aaa authorization commands 0 default  group tacacs+ local
aaa authorization commands 1 default  group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
you also need to add permit for exit and dir on the permit unmatched Args.
OR
You may check permit unmatched Args this option for exit and dir
Jatin Katyal
- Do rate helpful posts -
~Jatin
13 Replies 13
aneelaka
Is there any way to give priviledge level 15 and deny write access (write command)?
Yes.
You can try this: Privilege for read-only access
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml#scenario2
Jatin Katyal
~Jatin
I tried that and could not get it to work.
I tried the following:
- 1 -
Deny
Unmatched Commands - show
Permit Unmatched Args - checked
Enable Options
Max Privilege for any AAA client - 1
Tacacs+
Shell Command - checked
Privilege level - 1
With the above, the user did not have the ability to do sh run.  The user could not turn on privilege commands (enable) - access denied
- 2 -
Deny
Enable Options
Max Privilege for any AAA client - 15
Tacacs+
Privilege level - 15
With the above, the user had full read/write rights
Any other thoughts?
Dtom,
You need to give privilege 15 to both type of users. Now giving priv 15 does not mean that read-only user will be able to get full access. Command authorization work above privilege level.
Set enable and shell priv to 15
Rest your setting is all ok.
~JG
I don't know what I am missing here.  When I give privilege 15 the user had full access.  Here is what I did:
- 1 -
Create Shell Command Autorization Sets - Read_Access
  Deny - checked
- 2 - Create Group - HelpDesk
  Enable Options - Max Privlege for any AAA Client 15
  Shell (exec) - checked
  Shell Command Authorization Set - Assign a Shell Command Set for any network device- Read_Access
- 3 -  User Settings
  Group to which user is assigned HelpDesk
  TACACS+ Enable Control - Use Group Level Settings
  Shell Comand Authorization Set - As Group
Are you sure you have this on the device (Switch/Router)?
If possible attach a screenshot of the configuration on ACS.
Rate if it helps
**Share your knowledge. It’s a way to achieve immortality. --Dalai Lama** Please Rate if helpful. Regards Ed
Here is my switch AAA config:
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa authorization commands 0 defalt group tacacs+ local
aaa authorization commands 1 defalt group tacacs+ local
aaa authorization commands 15 defalt group tacacs+ local
aaa accounting commands 15 default start-stop group tacacs+
Here are screen shots for a user - robin.hood
As per your configuration:
All three lines have:
"defalt instead of default"
I am not sure if you just typed it wrong over here, if this is what you really have, then the IOS will consider this as the method list and will expect you to apply it on the vty or console lines (which is not mandatory, but it will not work until you apply it)
You have to use default, if you don't want method lists.
Rate if useful
What a dummy I am...typo.  I changed the commands and I was able to login and run the show run command.  However, I was not able to run exit and dir.  What am I missing here?  Here is a screen shot:
OR
Jatin Katyal
~Jatin
That was it.  Thanks.
So, what is the easiest way to restrict a user to access only a certain device or certain subnet only?
