ACS SE Agent for Win2k8 R2 64 bit
I have just added some new domain controllers that are running Win2k8 R2 64 Bit and am trying to link them to our Cisco ACS SE to authenticate based on active directory credentials.  However I can't seem to find any ACS Agent software to load on the new domain controllers.  Is there updated software available for this or another way to link Win2k8 R2 64 Bit Active directory to an ACS Solution Engine?
Jim
1 REPLY
Re: ACS SE Agent for Win2k8 R2 64 bit
Hi Jim,
Considering you are using ACSse 1113 4.2 version, Actually Remote agent 4.2 only support
Windows Server 2008, Standard Edition with Service Pack 2
Windows Server 2008, Enterprise Edition with Service Pack 2
And not R2.
http://ciscosystems.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2.1/Release_Notes/acs421_rn.html#wp1050574
TAC has already opened new enhancement  request for ACS 4.2 support  with 2008 R2. I Development is working on it  and we should get an  update in some time.
Latest  filed  enhancement is CSCta35271 which is internal for the time being  but  other one which was filed earlier is avilable to view i.e. CSCtd56660:-
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCta35271
thanks,
Vinay
Do Rate, it helps other customer
Thanks & Regards
476
