09-25-2008 05:06 AM - edited 03-10-2019 04:06 PM
After reading the documentation regarding the NIC cards on the ACS appliance it seems the both cant be used together. Can one be used as a management Interface like on CS-MARS and IPS? while the other performs its normal operation?
Solved! Go to Solution.
09-25-2008 01:34 PM
unfortunately no, you can only use one NIC that too bottom NIC (NIC 1).
If you want such a feature, you may want to contact your AM, and go for a feature request on this product.
Prem
Please rate if it helps!
09-25-2008 01:34 PM
Prem
09-27-2008 06:55 PM
One last question..........Whats the purpose of having two NIC's on the appliance if only one can be used?
09-28-2008 07:34 AM
future use/new feature/development. But currently it is not used
