ACS upgrade to 5.5 Patch
rakeshvelagala
Level 3
Level 3
Hi All,
According to Cisco there is a need to install  Patch: Pointed-PreUpgrade-CSCum04132-5-4-0-46-0a.tar.gpg before upgrading to 5.5. Our current system running 5.4 has the latest patch 5-5-0-46-1.tar.gpg already installed.
I am aware that the patches are cummulative and if we install the latest it covers all the below patches. but the readme did not specify the Bud ID
CSCum04132. Can please advice do I need to install patch  Pointed-PreUpgrade-CSCum04132-5-4-0-46-0a.tar.gpg before upgrade?
Jatin Katyal
Unsure how on ACS 5.4, you've applied patch of ACS 5.5. The patch 5.5.0.46.1 is meant for ACS 5.5.0.46 only.
The pointed-preupgrade patch is not covered by any cumulative patch as it's a special patch.
In order to upgrade ACS from 5.4 to 5.5, here is the process:
1.] Apply the latest patch i.e patch 5-4-0-46-6.tar.gpg
2.] Apply the pointed patch i.e Pointed-PreUpgrade-CSCum04132-5-4-0-46-0a.tar.gpg
3.] Then run the 'database-compress' on ACS CLI.
4.] apply ACS 5.5 application upgrade i.e ACS_5.5.0.46.tar.gz
Hope it helps.
~BR
Jatin Katyal
**Do rate helpful posts**
~Jatin
8 Replies 8
Jatin Katyal
Hope it helps.
~BR
Jatin Katyal
~Jatin
Hi Jatin Katyal,
Thanks for your reply. Can you please advise why we need to run 'database-compress' and its purpose.
Hi Jatin Katyal,
Sorry my Bad. The applied patch is
Cisco ACS VERSION INFORMATION
Version : 5.4.0.46.1
Internal Build ID : B.221
Patches :
5-4-0-46-1
So I still need to apply this pointed patch?Please advice
To reduce the ACS database size by removing unused disk space from within ACS database file use the database-compress command in the ACS Configuration mode. This command has the option to truncate ACS transaction history.
This command does not erase or modify any information during the database compression except for the transaction history if the truncate flag is used.
When you run this command, ACS is stopped and the process of compressing ACS database is executed and ACS starts automatically after the process is over.
The progress of the command execution is logged in the ADE.log file.
database-compress [truncate_log]
Reference:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-3/command/reference/cli/cli_app_a.html#wp1938829
Aishwarya Srivastava
++ Yes, you need to apply pointed patch before you begin the upgrade fron ACS 5.4 to ACS 5.5.
++ You must intsall the ACs 5.4 latest patch 6 and then apply the pointed patch i.e. Pointed-PreUpgrade-CSCum04132-5- 4-0-46-0a.tar.gpg.
++ After that you can do application upgrade to ACS 5.5.Once upgraded to ACS 5.5, ypu can install patch1 i.e.5.5.0.46.1.
cciesec2011
Level 3
Level 3
How come when I opened a TAC case with Cisco TAC, the TAC engineer told me as follows:
2.] Then run the 'database-compress' on ACS CLI.
3.] Apply the pointed patch i.e Pointed-PreUpgrade-CSCum04132-5-4-0-46-0a.tar.gpg
In other words, he told me that I "must" run "database-compress" PRIOR to installing the Pointed-PreUpgrade patch.
Which is the "correct" method?
I have upgraded recently and I did not use database-compress. Below is what Cisco got to say abt the command.
"database-compress :To reduce the ACS database size by removing unused disk space from within the ACS database file, use the database-compress command in the ACS Configuration mode. This command has the option to truncate ACS transaction history.
This command does not erase or modify any information during the database compression, except for the transaction history if the truncate flag is used.
When you run this command, ACS is stopped, and the process of compressing the ACS database is executed. ACS starts automatically after the process is done.
Rakesh
In ACS 5.5, instead of doing it manually, cisco provided an option in GUI to select and it does it every day at a certail time.
So it is recommended to do that, but I do not think it will cause any issue.
Rakesh
