ACS v5.2 - Unable to add enumeration attribute to compound condition
rodmunch999
     I have created an Internal User attribute and made the attribute type Enumeration so that only certain values can be selected. I am trying to apply this attribute to a compound condition. However, when I select the value of the enumerator for the compound condition none of the configured values show in the pop up window. (It is easier to explain with the screenshots.). Is there a way this can be done? Any advice would be appreciated.
Many Thanks
Dave
jrabinow
Level 7
Level 7
I recreated your issue both in ie and firefox. I tried to remove the spaces from the enumerated strings but it didn't help
Note the enuemrated conditions do work for simple conditions. That is when in you customize the table you select CAR as a condition; rather than using a compound conditon.
I did find a CDETS for this issue:
CSCtg51846: Enum values are not shown in compound conditions in rule
jrabinow
Level 7
Level 7
Thanks for the reply. Hopefully this will be fixed in a new patch.
