ACS5.x and IPSO6.2
Does anyone have any experience in using Nokia IPSO with ACS5.x and non-locol accounts ( on the Nokia )
I`ve created a shell profile with the following config :
Attrib: service Value: nokia-ipso
Attrib: Nokia-IPSO-User-Role Value: "role_name_on_IPSO"
Attrib: Nokia-IPSO-SuperUser-Access Value: 1
All optional.
The user is passing authentication but is denied access on IPSO as "user not configured for Voyager".
I`m not 100% the config above is accurate as any previous instructions were based on 4.x & Interface config.
1 ACCEPTED SOLUTION
ACS5.x and IPSO6.2
I found the same attributes can you check the service attribute and see if it is case sensitive, also try making them mandatory.
Here is an example that i found -
Service is nokia-ipso
Nokia-IPSO-User-Role=adminRole
Nokia-IPSO-SuperUser-Access=1
Tarik Admani *Please rate helpful posts*
ACS5.x and IPSO6.2
ACS5.x and IPSO6.2
Thanks - Mandatory is required it seems !
507
