Alarm caused by ACS - Process Status threshold
pugalendi.d
:Fri Sep 12 10:30:00 IST 2014
:Alarm caused by ACS - Process Status threshold
:Following processes were not running between Fri Sep 12 10:28:00 IST 2014 and Fri Sep 12 10:30:00 IST 2014 for the ACS Instance(s):
ACS InstanceTimeProcesses
Name:ACS - Process Status
Description:ACS database, management and runtime process monitor
Monitored Processes:ACS Management
ACS Runtime
Monitoring and Reporting Collector
Monitoring and Reporting AlarmsManager
Monitoring and Reporting JobManager
Monitoring and Reporting LogProcessor
Filter
ACS Instance(s):acsserver
Note:ACS - Process Status
mohanak
Just check the BUG: CSCum71084
Alarm suppression feature is not working for threshold alarms (like System Health, Process status alarms) which are defined in Monitoring and Reports > Alarms >Thresholds. System is flooded with duplicate alarms for hard coded evaluation cycle.
