apply AAA for LAN & L3 switches
I have a RADIUS server that I want to use as a central authentication location
I have a 3560, 3550 & 2950s. I know the 3560 can be configured with AAA, what about the other switches?
what is the best and safe way applying it?
Re: apply AAA for LAN & L3 switches
The 2950 and 3550 series support RADIUS authentication. Make sure you test it before implementing it. Also telnet/SSH in to the switch, make the change and open a new connection to test RADIUS. That way if it does not work you still have your first connection to fix it.
Hope that helps.
how would it work?
on the 3560 I'm prompt for user\pwd. on both 3550 & 2950 there is only a pwd prompt...
It should be prompting for both. Can you post your AAA config?
I didn't config it yet, I'm learning the HowTo at the moment
when I said that I get only the password prompt I refered to the existing IOS built in telnet login
OK. Today you have a password assigned to the VTYs and that is all that is needed to gain access. Once you configure AAA (either locally or with an external AAA server) you need to also provide the username. The password can be removed from the VTY lines because it will no longer be used. It is best practices to add a local username/password for backup in case the AAA server fails. When you configure AAA you will specify the AAA server first and 'local' as second in the authentication list.
yes, currently I'm using local database for VTY access which only require password, no usernames
I want to make all VTY connection authenticated via RADIUS
are these the correct commands?
aaa new-model
aaa authentication login
where\how to configure RADIUS?
looking at the commands I see TACTAS but not RADIUS
You need a little more-
aaa new-model
aaa group server radius RADIUS_AUTH
server 192.168.1.50 auth-port 1812 acct-port 1813
aaa authentication login DOMAIN_AUTHENTICATION group RADIUS_AUTH enable
radius-server host 192.168.1.50 auth-port 1812 acct-port 1813 key SeCrEtKeY
line vty 0 4
login authentication DOMAIN_AUTHENTICATION
this is what I've done:
aaa new-model
server 192.168.200.18 auth-port 1645 acct-port 1646
radius-server host 192.168.200.18 auth-port 1645 acct-port 1646 key SeCrEtKeY
now the result is a username prompt BUT it doesn't connect my RADIUS and as a result, login fail.
is there a way to configure the RADIUS and test it before I apply it to the login?
Not that I know of and that's why you should keep the first telnet session open and connected! What are you using for a RADIUS server?
I'm using Microsoft IAS
it is working with my ASA5505 for the VPN clients
and don't worry, I did keep the telnet open and tested on a different screen
oh, and I'm currently testing this on a 3550
for the record,
from my ASA I can test successfully:
ASA(config)# test aaa-server authentication vpn
Server IP Address or name: 192.168.200.18
Username: username
Password: ********
INFO: Attempting Authentication test to IP address <192.168.200.18> (timeout: 12 seconds)
INFO: Authentication Successful
this is the config:
aaa-server vpn protocol radius
aaa-server vpn host 192.168.200.18
key ********
same IAS server, same subnet
I also tried configuring a new policy on IAS as described here: http://www.blindhog.net/cisco-aaa-login-authentication-with-radius-ms-ias/
found a solution :)
credit to this link: http://briandesmond.com/blog/how-to-authenticate-against-active-directory-from-cisco-ios/
conf t
aaa new-model
radius-server host 192.168.2.18 auth-port 1812 acct-port 1813 key ********
ip radius source-interface vlan200
aaa group server radius RadiusServers
server 192.168.2.18 auth-port 1812 acct-port 1813
exit
aaa authentication login default group RadiusServers local
exit
Great, so everything is working correct?
yes it does
thanks for the help
273
