ASA5520 for limited operators
dimaonline
I need limited access to cisco ASA 5520 for same operators. This operators can switch on/off vpn policy ONLY
I grant "privilege cmd level 3 mode group-policy command vpn-tunnel-protocol","privilege cmd level 3 mode exec command configure" and "privilege cmd level 3 mode exec command write"
But I receive error on "write memory" command:
write memory
Building configuration...
Error executing command
[FAILED]
Why?
PS: write terminal WORK.
8 Replies 8
Tarik Admani
can you paste the ouput for the following:
"show run privilege command write"
Tarik Admani
# show run privilege command write
What version is your ASA on?
thanks
Tarik Admani
Cisco Adaptive Security Appliance Software Version 8.2(5)13
Device Manager Version 6.4(7)
I checked the bug toolkit and didnt see a match for this error, its clearly configured correctly from what I can tell. I would suggest opening a TAC case to see if there are any internal bugs that may not have been public yet. Do you have another ASA that is running a different version experiencing the same issue?
Tarik Admani
I have second ASA but it have same version.
I haven't smartnet for opening TAC.
I think a problem in access to flash for level 3
Hi Bro
Yes, your assumption is correct. WRITE MEMORY COMMAND can only be executed by usernames with privilege 15 ONLY. I did a simple test just for you in my lab, as shown below;
username ramraj password xBXQhLMSw3EzEgAY encrypted privilege 15
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 7
privilege cmd level 7 command write
aaa authentication serial console LOCAL
aaa authorization command LOCAL
aaa authentication enable console LOCAL
Username: cisco
Password: *****
Type help or '?' for a list of available commands.
FW1> enable
Password: *****
FW1# write memory
[FAILED]
FW1# show curpriv
Username : cisco
Current privilege level : 7
Current Mode/s : P_PRIV
Warm regards,
Ramraj Sivagnanam Sivajanam
hhoujou
you must also change copy command
exp.
privilege cmd level 3 mode exec command copy
