Authorizaton of ASA 5550 with AAA
Well I have a ASA which I tried adding in ACS with TACAS+ protocol. I was able to authenticate with my ACS user but was unable to run any command which says "Command Authorization Failed".
The ASA configuration is attached for reference.
I have one doubt also as whether it is possible to have authorizaton of ASA with RADIUS protocol.
Thanks in advance
Ritesh
Re: Authorizaton of ASA 5550 with AAA
Ritesh:
On the TACACS+ server, configure the commands that a user or group can use after they authenticate for CLI access. Every command that a user enters at the CLI is checked with the TACACS+ server. Looks like you haven't configured any shell command set on the ACS.
Here is a Doc that helps you configuring command set on ACS:
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_configuration_example09186a00808d9138.shtml
Also, radius doesn't support command authorization.
Let me know if you have any query/concern.
JK
Plz rate helpful posts-
~BR Jatin Katyal **Do rate helpful posts**
Also, if you just want to authenticate you user with RADIUS when doing telent and you don't want to authorize on a per command basis you can remove the "aaa authorization command CACS LOCAL" command.
I hope it helps.
PK
497
