Cascade a switch to a dot1x port
Need help.. I'm trying to cascade a un-managed switch to a parent swith with a dot1x enabled port. IOS Ver of both switches (slave & parent ) are dot1x compliant.
Config Settings of my Parent switch:
dot1x system-auth-control
dot1x guest-vlan supplicant
int f0/15
switchport mode access
dot1x port-control auto
dot1x host-mode multi-host
dot1x timeout quiet-period 3
dot1x timeout tx-period 15
dot1x max-req 5
spanning-tree portfast
No configuration is set on my slave switch because I want to do a straightforward cascade. Is it possible ?
Thanks...
1 REPLY
Silver
Re: Cascade a switch to a dot1x port
I am not sure if this is possible. If you are connecting two switches, then the ports need to be trunk ports. Right? I guess dot1.x will work on the access ports only. Anyone any comments?
227
