03-01-2006 08:04 AM - edited 03-10-2019 02:29 PM
We have a catalyst 5509 running the old CatOS. I have everything with Tacacs set up correctly to log in but it won't pass through any login directly to enable mode. After I log in then I have to enter the enable password. All of our other routers work fine. I am not sure if I just missed a command or not. I have attached the 2 sections of the config for you to look at. Any ideas on how I can make it go directly to enable mode?
03-01-2006 11:25 AM
The config you have got simply 'enable' the use of tacacs for logging into the console and for telnet sessions. In order to have a user log directly into enable mode, configure your TACACs server to give the user a privilege level of 15. The following document describes how to do so:
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a008009465c.shtml
Hope that helps - pls rate the post if it does.
Paresh
03-02-2006 06:25 AM
We currently have our Tacacs server assigning privilege level 15 to our admin users. This works with all other routers/switches that we have (all run native IOS). It's on on this Hybrid IOS switch that I am having this issue. That is why I think maybe I am missing a command for the authorization, but since I am not very familiar with the Hybrid IOS I wasn't sure what I am missing... Any idea?
03-03-2006 08:26 AM
Ken
I suspect that what you need is to include set authorization enable enable tacacs if-authenticated to your config.
Give it a try and let us know if it works.
Rick
