Cisco ACS 1121 Amperage
I am trying to determine the maximum amps rating for the Cisco ACS 1121.  The Model is CSACS-1121-K9 V01
Re: Cisco ACS 1121 Amperage
It has a 350W power supply. Amps should be less than 4~5 A when using 110V input.
Thanks for the information.  I decided to simply divide the maximum Watts by maximum Volts.  My answer was 3.
1117
