01-26-2006 05:54 AM - edited 03-10-2019 02:27 PM
HI,
It is possible to upgrade from CS ACS 3.3 to 4.0 on ACS sOlution Engine 1111, which is EOS since end 2004???
If not should I upgrade first the HW from 1111 to 1112 and then the ACS?
02-01-2006 07:54 AM
ACS supports the following upgrade paths. These paths have been tested and are supported:
ACS SE release 3.3.3 to ACS SE release 4.0
ACS SE release 3.3.2 to ACS SE 4.0
ACS SE, release 3.3.1 to ACS SE 4.0
ACS SE, release 3.2.3 to ACS SE 4.0
ACS SE versions before ACS SE 3.2.3, first upgrade to ACS SE 3.3.3, then to ACS SE 4.0.
03-17-2006 04:08 AM
I dont see ACS Solution Engine 4.0 released for anyhting except windows / unix. When will 4.0 be released for the actual appliance?
